I'm finally back on the project of improving the last section of our house. What we have is a 1960s contemporary that was built with a vented cold deck roof with BUR tar and gravel--rough size is about 800sf. Original roof was replaced sometime in the 1980s so roof is 30+ years old. Currently, it is not leaking, but there are a couple of spots where the copper flashing sealing has started to fail.
Given the budget, I'm tempted to clean and re-coat the existing roof, except the only insulation is about a 2" foil backed layer of ?rock-wool. So I think I need to strip and replace the deck or remove the drywall underneath to get into the rafter cavities to insulate.
-Will I likely find the base coat mopped to the plywood decking and therefore should I expect to have to replace the plywood? (If so, I can do the insulation from the top at the same time & save the drywall...)
-Since we are on a strict budget, can the copper flashing be re-used?
-Hardest question--what type of insulation/application? This thread discussed some of the possibilities, but was a bit inconclusive.
If I use standard fiberglass batts, I am limited to R25 (8"-8 1/2") or R30 (high density) to maintain a 1" airspace above the batts for the deck ventilation. (2x10 16" OC, continuous vented soffit)
I thought about foam, but can the installers fill the joist cavities and leave a gap, or would you need to spray and then install furr strips?
