Code for dryer vent?
Tags
dryer vent
5.2K views 19 replies 8 participants last post by  Priusron
hey guys;
My gas dryer (in the basement) has a piecemeal vent hookup.
I want to fix it so it meets local code. I live in the U.S.
I have posted several pictures of the current config, which I am certain does not meet code.
Several things I can point out immediately:
1. There is no secure means to attach the flexible hose to the pipe that goes through the wall to the outside vent hood. Note that this pipe is flush with the wall.
Originally, I believe there was a 90 elbow inserted into the wall pipe, but from the outline around the pipe (hole in the wall) there was once a flange mounted there. That said, there are no screw holes that would have been used to screw the flange to the wall.
I would assume that I need to secure the inside pipe/hose to the one through the wall by a clamp. My best guess is that i need to install a flange which would have a connection for the hose from the dryer.
2. I would also assume that I need an elbow (perhaps I can re-use at least part of the rigid pipe) coming out of the dryer, rather than connect flexible hose directly to it. My thinking is that without an elbow, the flex hose can easily get kinked and blocked.
So I guess what I really need to know is where I can use flexible hose, and what type of fittings I need to connect it properly at each end.
Also, what sort of support do I need?
Obviously, the wire now holding the pipe/hose is not code.
Images of current config:
Rigid pipe exits the dryer.
Flex pipe attached to rigid pipe
Flex pipe is stuck into pipe through wall using short rigid pipe with clamp
Flex pipe removed to show pipe through wall
Thanks for your help
Ultrarunner
It's pretty much a standard plastic vent. I will post a pic shortly.
What I like about flex pipe is the ability to make it fit without cutting any of the rigid pipe. I have a tin snips though, so I suppose it wouldn't be so difficult to do so. I would need to wear heavy gloves to prevent getting cut up of course.
As it stands now, I have been periodically (about 1x /yr) removing the entire vent system and removing the lint buildup. I can do this either by shaking/banging the pipe on the driveway or using a shop-vac to suck it out.
#7 ·
Hard pipe is the best but not always practical. Plastic flex hose/duct is a no-no. The expandable aluminum flexible pipe in the picture should be fine(?)
As far as the outlet is concerned, you could use a flanged adapter that screws to the wall and inserts into the pass through or just install a new hardpipe through the opening and terminate the exterior with a new animal/bird-proof cap (good luck finding one these days).
#8 ·
Thanks guys; I can go with the hard pipe. It really shouldn't be a problem. I can probably re-use the two 2ft sections that are connected to the dryer now, as I don't see anything wrong with them.
So far as a animal/bird proof cap, the one i have now does have a flapper inside. I'm not sure if that is what you're talking about or not.
I guess a trip to the local DIY store is in order.
#9 ·
The code in NY only allows flex pipe as a short connector from the dryer to a hard pipe that is in close proximity to the appliance.
#12 ·
It looks like I will need some sort of collar or flange to mount to the inside wall and attach to the pipe coming through the wall so that the interior piping is securely attached.
I'm trying to find such a part but don't know what to call it. There was originally something like that, going by the 'shadow' on the wall
#13 ·
Use rigid duct all the way through. People use flex because its fast and easy, but rigid is less restrictive and collects less lint (and looks better and not amateur). I don't buy that going full rigid is not possible.
That outdoor exhaust vent has two holes for fixing it to the wall. Better yet, buy a new exhaust vent -- that one looks like it has been taking the UV's for a while - not sure how much life it has left. (should be four holes anyways IMHO.) Caulk perimeter after fastening.
Buy a crimper for joining ducts. Note that there is a right and a wrong way in deciding which piece to crimp. No screws into the ducting.
#14 · (Edited)
Thanks for the vid;
I never gave those crimps any thought; figured the pipe came that way.
I'm still not clear on how the pipe inside the house connects to the one coming through the wall from the outside vent hood. It is too short to put a clamp or tape the joint.
So I'm thinking that normally that pipe (the one with the hood at the end) should be longer, which would allow proper clamp/tape to the next length of pipe.
I think that going to the DIY store and having a look will help me figure everything out.
If I buy that crimping tool, this will be my only use for it, so I'm going to get a cheap one.
Wondering whether this vent hood will last, or become stuck after a year or so, refusing to open when the dryer is running - just like my kitchen vent flap:
https://www.homedepot.com/p/No-Pest...com/p/No-Pest-Vent-4-in-Low-Profile-Dual-Door-Wall-Vent-in-White-NPVW/207125511
Of course, there's no grease involved here as there is with the kitchen vent.
#15 ·
Took another look in the laundry rm.
The wall where the vent goes through has a shadow from a flange, but no screw holes.
Measuring the length of the pipe from the hood, it is 12in. The foundation wall is about 1in thicker than that, so the pipe actually ends before it gets fully inside the house.
Note that this house is nearly 100 years old. I guess no one builds homes with foundation so thick anymore.
I will probably have to buy the vent hood and another length of pipe to use instead of the 12in long one that comes with it. At least if I have some pipe (inside) to work with, I can properly tape the joint.
#16 ·
The flexible duct can only be used as a transition from the dryer to the permanent exhaust duct and cannot be longer than 8'. The remainder must be rigid metal duct. Taped joints are not required, just one of the acceptable methods of joining ducts.
One end of round sheetmetal is pre-crimped, you should not need to buy the crimper. It also comes in 5' lengths. I would use 'U' brackets attached to the concrete wall and keep it rigid all the way to the dryer.
