I'm reading conflicting information on circuit sizing for induction cooktops, I was wondering if someone could clarify. I've also seen some threads online with professional electricians debating the issue and quoting the NEC on both sides of the argument.
My installation instructions from Samsung for their induction cooktops say you use to use:
8 Gauge Solid Copper wire and a 45A breaker.
When I look up NM-B 8/3 wiring, i see it as a maximum 40A.
But to add to the confusion, when I go to Cerrowire and pull up this following chart: https://www.cerrowire.com/products/resources/tables-calculators/applications-charts/
They say 8/3 works on double-oven ranges up to 45A... while at the same time other chart for choosing wire based on amperage says to pick 6/3.
Obviously, 6/3 is more expensive and both Samsung and CerroWire seem to be calling for 8/3 on cooking appliances that draw 45A.... can anyone clarify this? Last thing I would want to do is run $150 of wire, only to have to rip it out after inspection, and I'd hate to run more expensive wiring than necessary.
