Tried replacing the thermostat to find five wires going in to a double pole thermostat. Four of the five have 120V on them connected to two breakers. The one wire with nothing doesn't go to ground but was connected in to the load side. I noticed two white wires with wire nuts on them in the box. One with a red wire that is hot 120. The old thermostat did not work correctly but did work as long as it was turned almost all the way off. If I turned it up at all it would not turn off no matter how hot the room got. All of the other thermostats in the house are single poles. Its a pretty old system
Thanks for any insight.
