Capping a threaded pipe that has been cut
4 reading
2.2K views 16 replies 9 participants last post by  supers05
I've got a bathtub spout pipe that looks like it was cut off about halfway up the threads. No connector or cap will thread on due to the taper. Is there any way to salvage this? I don't care about putting a new spout on, but I'd like to cap it just to use the shower if possible.
#6 ·
You can try a plastic cap. The threads are the same and they will "give" a bit.
Grey plastic are often used for well systems.
But if it absolutely doesn't budge, you can thread it to accept a cap.
It will take a bit of muscle though.
#10 ·
Pretty minimal if the pipe isn't rotten. If you get it out put a new nipple and cap on using tfe paste.
Or find a Fernco cap for temporary use.
#12 ·
Spouts that slip over a pipe are available. You don’t want a spout but it will solve your problem.
#14 ·
I think your best bet here is to remove the old nipple and replace with a shorter one to cap or just plug where it went. Since you say it's tapered I picture galvanized or brass. Pipe wrench and make sure you're turning the right way!
There are threading tools out there but they can be pretty expensive and difficult to use.
#15 ·
You could get a cap and try to pre stretch it by threading it onto a new nipple as far as you can. Do that a few times and maybe you will be able to get it onto the cut threads.
I’m guessing if the threads are cut then someone probably cut off an existing fitting so the threads are probably all too big to thread into a fitting (like you described, so even if the above method worked you probably wouldn’t get it to thread on enough threads to hold under pressure with any level of confidence.
Are you planning to pressurize the pipe later or is it jut to clean up the open end?
