Can I spray WD-40 into my garbage disposal?
1 reading
13K views 9 replies 9 participants last post by  Geochurchi
When my kitchen was remodeled several years ago, I added a garbage disposal to the new sink. However, these days, I find I have very little need to use it. The last several times I've tried, it's been frozen and I've had to use the big allen wrench to get it moving. I felt down inside and found rust on the lower wall of the grinding area. Given that all the sink drainage goes through the disposal, I guess this shouldn't be a surprise. So, would it help to get my trusty can of WD-40 and spray in there? while it's running? Or is it a lost cause? If it's shot, taking it out would add quite a bit of under-sink storage.
Thanks!
#8 ·
Don't EVER put motor oil down a drain, septic or otherwise.
Reactions: bob22 and mark sr
