Can I ceramic tile on to linoleum?
2K views 6 replies 6 participants last post by  fabricator
#1 · (Edited)
I have a bi-level home which is only 9 years old and has a linoleum kitchen floor upstairs. The linoleum is in good shape its just do for a change. I plan on using 20 inch plus ceramic tiles (so big tiles, not sure if this matters). Under the floor would be just plywood, so if I can't lay the tile on the linoleum, would I have to lay down cement board down? The floor is level and smooth so there is no worry of things being uneven or having dips. The issues are raising the floor to much in comparison to the adjacent room, and of course to see if I can save a little money without effecting the outcome of the job. I know the right way is to take it out and lay a cement board down, just curious if anyone has had any success doing it this way.
Thanks so much.
Bryan
Sent from my HTC Evo using DIY Chatroom
#4 ·
20 inch tile is large format, and requires a much stiffer floor (measured by the L/D ratio) than smaller tile to prevent cracking of the tile. For a detailed discussion about floor stiffness and how to determine how stiff your floor is, see www.schluter.com
Schluter makes ditramat, which is a bond breaker commonly used to reduce the potential for tile cracking. Regardless whether you use their product or not, you absolutely need to determine the stiffness of your floor, which is a function of the size of joists, the span of the joists, the spacing of the joists, the load on the joists, and the type of subfloor you have. Floor stiffness is not affected by installation of cement backer board, so if your floor is not stiff enough for 20 inch tile, you need to develop a plan to increase the stiffness, else you should consider using a smaller format tile. The penalty for installing a large format tile on a floor which is not stiff enough is cracked tile, cracked grout, or both.
