When I opened my blower door on my XV95 furnace (to look at my pressure manifold) I noticed there was a lot of debris on the bottom of the return drop. After inspection I realized it was coming from my bypass
Humidifier pad which was positioned after the filter in my case. I immediately repositioned the Humidifier to a position before the filter so if the humidifier pad further deteriorates, at least the particles will be captured by the filter.
I have a horizontial filter installation in my return drop.
Below are pictures of the Humidifier positioned post filter (below filter) then later positioned before the filter (above the filter).
Hopefully the issue is solved and I did not inadvertantly create another issue. Does anyone think there would be a problem with the Humidifier in the new location?
Thanks
Key1
Thanks
Key1
