Ok. Getting warm this season and decided to check the ac to make sure it works. The past couple years I have had the ac not work upon first startup. The first year was a leak in the coil. It just popped when I turned it on and everything leaked out. The second year the unit turned on but no cold air. I replaced the capacitor to no avail. Called a tech and he pressure tested the entire coil, which was fine, and found a small leak in the valve where someone had tried to plug it years before it looked. He replaced the valve and that portion of the pipe. Everything worked perfect for the whole season. This year I turned it on and no cold air. Opened the side and saw the burned connection on the common. Replaced the wire and bought another new capacitor. Now the unit still does not blow cold air but it the fan runs but I cannot tell if the compressor is running or not. The pipe does not get cold at all. Maybe I re-wired it back wrong?
The compressor is a copeland.
Thank you in advance.
http://i.imgur.com/7pcGt.jpg
http://i.imgur.com/uUIWG.jpg
