Illustration and Photos
Thanks, Dick. I appreciate your taking the time to respond. I had tried to keep it as simple as possible, initially. I've attached a rough drawing and three photos, which should make some of the following more clear if you view them first.
The footing is much wider than the recommended width (about 4 inches on each side of the block), but there is no rebar.
There are two walls and they are built on a downhill slope. The first is rectangular, about 5 1/2 ft tall, supporting a concrete pad patio which is against the house.
The second, in the shape of an almost-half circle, about 4 ft at its highest. This curved secondary retaining wall lies about 9 ft. in front of the rectangular wall.
The taller, rectangular wall supporting the patio has sand-clay in front of it (leaning against it), beginning about 2 ft from the top of the wall, sloping downward toward the secondary wall. The remaining space between the highest wall and the secondary wall is filled with sand.
Therefore, sand-clay is the primary soil pressing backward against the primary wall (supporting the concrete pad patio that connects to the house, and sand is the primary soil pressing forward against the secondary wall.
The secondary wall, the curved one, has a 2 ft high sand-clay support against it in the front.
There is a gravel, French drain system at the base of each wall.
Why does it need to be stabilized? There is some pulling away block from block, vertically in one section of the taller, rectangular wall (see photo). It seems to have halted at 1/2 inch gap. The idea behind rebar and concrete is to link the horizontal sections together, row upon row, to prevent this in the future. There are no problems on any other sections of the wall, but before any money goes into cladding the wall with stone, I want to be darned sure this is addressed to the extent possible at this point. My concern is that curved sections of the shorter wall are also under stress.
Why did the builder use 8" block instead of 12"? Well, lack of experience is my guess. Now, there is nothing left but to try to forestall -- to the extent possible -- future movement.
What grade grout do you recommend?
Since I'm cutting re-bar a little at a time, can I leave the cut pieces inside the wall for several weeks or will the slight rusting cause any problems once I finally insert the concrete.
Among my future questions, after this is addressed, will be: Will the soil base of mostly sand --but with clay sloping upward against the larger retaining wall be an acceptable base for a poured concrete patio? Or is the sand a poor base for a concrete pad? A concrete truck will be able to reach the edge of the location to be poured and damage will be minimal.
Thank you, again.
