Best way to secure the pipes
4.2K views 9 replies 2 participants last post by  HomeLearner
As I shared, I got my ceiling cut. The pipes seemed tightly secured at first (see the 1st photo). Then someone forcefully opened the brackets in order to put a layer of insulation between the pipes and the brackets (see the 2nd photo).
The brackets might have been damaged in the process, because the brackets are loose and some of them are in a crooked position (instead of in an upright position). See the 3rd photo.
I want to secure the pipes properly, before closing the ceiling.
Since it's almost impossible to see the pipes from the top, I may only be able to add brackets to the side of the wood joist. Correct?
Will the white hook (in the last photo) work? But the holes seem too small for any screw (for binding to the wood joist). Any suggestions?
How to secure a free drain pipe
I found an unsecured drain pipe in my ceiling (that had knocked on the ceiling once in a while). See the attached. I noticed there is a metal bar nearby.
What is a proper way to secure the pipe so that it won't knock on the ceiling and also won't touch the metal piece (to make noises)?
#9 ·
So far I've been to several hardware stores. Someone suggested using a hanger strap and screwing onto the wood on the side or even at the bottom. Since the materials for the hanger straps are hard metal or plastic, I wonder having to twist the hard straps to fit different surfaces may make it easy to break loose.
Some DIY type of person suggested loops. See http://www.homedepot.com/p/Watts-6-in-Nylon-Cable-Ties-100-Pack-RFCT/203353977?N=5yc1vZbqjc. But I don't know how to tie the end to the wood joist.
I don't see more variety of products in the hardware stores than Home Depot or Lowes. Probably I didn't go to the right hardware store.
After checking out the grainger web-site, it seems they may have more options. Just saw this at http://www.grainger.com/product/ANVIL-Side-Mount-Strap-WP112853/_/N-aa3?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4HYA8_AS01?$smthumb$
I will continue my research. Will give an update when I get some useful information!
#10 ·
To give an update, I researched on the idea of a plastic loop that goes in a hole of a screw on the side of the wood joist (see photo).
But I eventually got the plumber to do it. He used a hanger strap for the pipes (see photo). I think it a great idea.
He also added support with a hanger strap for the loose drain pipe, and insulation between the wood joist and the pipe to prevent knocking on that side (see photo). Since the screws he used were 2" long. Just hope the screws didn't penetrate something useful behind the wood!
