Best Way to Secure Short Wrought Iron Railing System to Brick Steps
13K views 12 replies 5 participants last post by  Curmudgeon10
My just purchased home needs a wrought iron railing for the three step entry front porch. The railings I am looking at all attach through plates on the bottom of the vertical pieces ("newels" if they were wood, I suppose) with four bolts to be sunk into the brick.
I installed the same sort of system at my last house, but it failed because the stress on the railing from use overcame the holding power of whatever I used to fix the bolts into the holes in the brick. Obviously I used the wrong stuff and don't want to repeat that this time.
What's the best way to permanently attach the railing to the steps (overhang on the sides of the steps prevents an attachment there).
Discussion starter · #5 ·
Link us to what you bought and post a picture of the steps and landing.
I haven't purchased anything yet. I get the idea of drilling through the brick into some solid surface, and that's what I tried on my last house, but the holes went through to voids. I also understand I could build a simple wooden railing system abutting the left edge of the step with posts in the ground but I hate the look.
Discussion starter · #13 ·
The height of the bottom step might suggest that you could have a concrete sidewalk below the pavers that you could anchor to.
Good point. I'm off the hook for this one. Look for a new thread on an interior railing system that I can easily remove if I need to move large objects (i.e., furniture) up and down the stairs. Probably up tomorrow.
