We just purchased this set of bunk beds for the grandkids when they come to visit:
https://www.amazon.com/dp/B01DTPH9XS
I have a few questions that I would appreciate help with.
1. After I got it all assembled, I tightened all of the bolts and screws. The next day, when the kids arrived, it seemed a bit wobbly. The bed was pushed into a corner, so I couldn't get to everything to re-tighten. After they left, I pulled it out and tightened everything again. Some of the bolts were quite loose, especially those that were connected to nuts that were inserted into a side hole. These are the little cylinders that you have to align with a screwdriver. Is it common for this type of bolt to loosen after the initial installation and have to be tightened again?
2. As you can see in the attached photos, there is no solid platform for the mattresses. It just has the cross slats. I am inclined to get a piece of plywood and add a platform. I have a couple of questions:
2a. Is plywood the right material or should I get particle board or pressboard or something?
2b. Is 1/4" plywood enough?
2c. What grade should I get?
2d. Should I screw it down into the cross slats?
2e. Should I attach it to the sides with angle brackets?
3. Photo 04 shows that there is an angle bracket under the side rails of the top bunk. Photo 05 shows that there is no angle bracket for the side rails of the bottom bunk. Should I add angle brackets to the bottom bunk? It's odd that they did the top and not the bottom. The bottom supports more weight.
4. The top bunk rests on the corner posts of the bottom bunk with 90mm (3.5") posts making the connection. The posts holes are lined with metal cylinders, but they are not a tight fit. And it is just sitting there without any positive connector. Should I attach a straight bracket to the inside so they are locked together? Is one bracket per post sufficient or do I need one on the inside and another on the outside?
Does anyone have any other suggestions? The kids can get a little rowdy, jumping and horsing around. I want to make sure the bed is sturdy.
Thanks for any help.
