Best way to cut soffit?
32K views 5 replies 4 participants last post by  rossfingal
Wasn't sure which forum this belongs in, but I've been using a metal cutoff wheel in my sidewinder for vinyl siding, and aluminum soffit on a sidejob. Does a carbide blade flipped backwards cut smoother? Thx. It's been awhile since I was a sising/soffit/fascia man ;). tom
Paneling blade turned backwards works best. But many times we used to use whatever blade was in the saw at the time and flipped it around.
Or you could just pull the saw backwards instead of using it like normal. We always had a "soffit table" that is more or less a cutting table with a guide to place your saw in to.
#5 ·
i like to use a sliding mitre saw to cut soffit and typically just use the blade thats on it turned backwards but if our tile guy is on site we will borrow one of his old diamond blades from his tile saw.
ive never cut vinyl siding or soffit with a circ saw. always with mitre saw or snips... the good thing about the mitre saw is that the fence keeps the peice in place, where as you need to build a cutting table so the siding doesnt get thrown
