Best Tools for Drywall Removal?
27K views 59 replies 18 participants last post by  gregzoll
So I'm starting a new project where I will be replacing the ceiling in a few rooms. Removal of the drywall ceiling seems simple enough, as is most demo.....But does anyone have any pointers/link to the best tool for the job? I have a drywall saw and dremel. I don't have a sledge, but for the ceiling I dunno if that would be the best tool for the job anyway. Is there any sort of must have drywall removal tool?
Also, for all the screws that will remain stuck in the joists....what is the easiest way to remove them? Simply unscrew them out if the screws aren't too mudded up, or is their a good tool I can use to just rip them out (if possible without causing too much damage).
Thanks for any tips.
#4 ·
If you use a bar and rip the screws out, they'll tear up the truss chords as they come out. Personally, I'd rip the drywall down, then unscrew. If they're plugged with mud, use some small vice-grips to remove them.
DM
#5 ·
DM
What about smacking them back and forth with a hammer until they break?
Sent from a Samsung Galaxy S2
#6 ·
That'd work too, but if it were me, I'd unscrew and clean them up and recycle them! (I'm cheap! :laughing: ) I'd also be concerned about not having a smooth, flat surface to reattach to.
DM
#8 ·
Ceiling drywall screws are required to be longer than the ones used on walls. If you crowbar them out, you'll almost certainly tear up the wood, making it weaker and less likely to have a good surface to re-screw to when you replace the required 5/8" drywall. If you do not want to reuse them, then I'd be inclined to go with titanoman's suggestion and break them off.
DM
#13 ·
Good point. Now that I think of it, I will be hanging my new ceiling using clips and a hat channel (this is a sound barrier project). So I probably can just leave the screws in there since there will be a 1.5" gap between the bottom of the joists and the ceiling.
#10 ·
Phooey !!!
There will be plenty of meat remaining for the new screws. Drywall screws are never that healthy to begin with. Scrape the splinters and go for it.
#19 ·
oh'mike and I were just talking on the phone (he was on his way to breakfast with a friend/client) and he suggested throwing down some visqueen plastic before you start! I have to agree! Then when you're done, just roll it up and dispose.....
This WILL be a messy project, guaranteed!! :)
DM
#26 ·
Are you going to use Green Glue between the drywall boards?
It's good to be learning all of this. I'm going to be tearing drywall out of 2 rooms in my basement soon.
Instead of taking the drywall screws out of the studs, would it be alright to use a multi-tool or a Sawzall to cut them off?
Also, would it be alright to use a circular saw to cut a line in the drywall from one end to the other between the studs? Of course, with the blade set slightly deeper than the thickness of the drywall to avoid hitting electric wires. I'm sure there's a reason why that won't work, but thought I'd ask.
#30 ·
I hadn't thought about the dust. Hmmm. I don't know if I have the strength in my hands to pull down drywall. I guess I'll find out :).
The Sawzall blades would probably be the cheaper of the two. Multi-tool blades are fairly 'spensive.
