best material for shop wall covering?
17K views 7 replies 6 participants last post by  vsheetz
Just got done pouring the slab for my shop, am planning on stick frame construction with sheet metal/colored tin for the outer covering and insulating and covering the inner walls. Since I will be doing a lot of grinding and such and fire is a potentail hazard I had thought of sheet rock, and maybe put something like trim coil on the wall behind the work benches.
What other material would be good? Needs to be smooth and somewhat fire resistant, at least as much as say drywall, and economicle, read cheap.
Thanks
#4 ·
I was in Menards the other day and they had a steel siding intended for use as interior wall covering. You could put that over osb. I don't think osb is required but I would use it for "dent reduction" and to make it easier to hang things. Obviously a lot more expensive than drywall.
#7 · (Edited)
Thanks, figured on thin metal 2' strips around bench top hight. Majority of hot work will be outside under the drop shed, outside walls will be metal roofing and gravel floor so no fire hazard there. Inside will be some grinding, mostly machine work and hand finishing. Probably worrying over nothing, but mainly don't want dust to acumulate in rough surfaces. Even though hot work will be out side there will be the posability of fire from heat treat and solder/brazing. Also titanium dust can be very flamable and extreamly hard to put out, that's one reason I rejected particle board, too many nooks and cranies for it to build up in.
