best adhesive for mirror to plywood?
2 reading
23K views 9 replies 4 participants last post by  chloe761
Hi, I'm making a decorative mirror. It was a Rona project that takes a mirror, and adheres it along with tile and moulding to a peice of 1/4" plywood. THe instructions say to use tile mortar. That does not seem to hold and I really want to use the strongest bond possible so this does not come apart and shatter once hung on the wall. A gentleman at Home Depot this morning suggested Omni Grip and said this would be the best and could be used for the tiles as well as the mirror, and I had already picked up super No More Nails for the moulding. Will this all work, or is there a better adhesive for this project?
Hi and welcome to the forum.
the No More Nails should work just fine.
glue it all down, leave flat on a level surface a day (overnight) to allow plenty of time for the glue to set tight.
i advise NOT using gorilla glue in this case. it foams up. but it's great for other situations.
DM
#4 ·
hmmm, my fault for assuming No More Nails is pretty much the same as PL Construction Adhesive.....
i've never used NMN before. i use tons of PL though... good stuff..... try that.
or maybe some floor tile adhesive. that's pretty strong stuff too. test the different glues on scrap pieces first.
not sure what weights are being applied to this setup and how. do you have pics you could post? it might help.
DM
#10 ·
Thank you all for your replies. It was very helpful and appreciated!
I have heard of that mirror mastic in my research and will definately try to find some when I do this project again, which I will shortly because it is turning out absolutely beautiful!
We used the Omni Grip last night for the mirror and tiles and it seems to be doing the job. Through my research however I read about a very lengthy drying time with this product so I will let it sit until Sat. and check it out then before grouting and securing the moulding. The reviews advised not using this product on floor tiles or anywhere in direct heat, so I should be safe with this product.
I did learn a valuable lesson through all of this, and from navigating this site....to not assume the sales people know what they are talking about. I will be sure to research project subject matter here, before starting my next project!
Thanks again for all of your help!'
I will drop a line on the weekend and let you know how the product held.
