Baffled by Door Framing for new deadbolt strike
4 reading
1.7K views 15 replies 5 participants last post by  Zeugitai
I'm putting a second deadbolt in the front entry door at a height of five feet from the ground. I installed the deadbolt in the door _very_carefully_ and had no problem. I located and drilled a 1" hole for the deadbolt strike plate. The hole I drilled went though about one inch of wood, and dead ahead I could see the lath. To the right, the plaster, to the left, what looks like wood (best I can see in there). This is a 1920 building. I tried to drill into the wood to the left of the lath, but the drill will not/cannot penetrate whatever it is in there. I'm stuck. I've gone all the way with this installation to the last step, and I can't get the screws for the strike plate in! I can't imagine what is back there that the drill can't penetrate. I hated to do it, but I tried to drill at a greater angle (to the left, toward the outside), but still the drill would not penetrate. I'm baffled. Has anyone ever run into some kind of impenetrable layer of something in this position?
You may not be able to use the longer screws in the plate due to the obstruction. Since it is a tertiary lock, they may not be needed, although ideal. Try installing shorter screws to fix the plate and see if that works. Will the bolt complete its throw?
Thanks, Chandler. That seems to be my only option. I laid into it with a new drill bit and got nowhere. The shorter screws go into the 'jamb' wood (if that's what it's called) to a depth of 3/4" or 1" (the thickness of that board), but there's no real strength in it. Behind the jamb, there is an empty space across which I can see the end of the lath with the plaster for the living room wall. I was trying to drill into the wood to the left/(toward the outside) of the lath, but the drill goes nowhere. I just can't imagine what is going on there. I expected to find the framing wood for my screws, but that is not the case. With the short screws holding the strike in the jamb board alone, there is no real strength in it. I feel that this deadbolt was a waste of time and money. Nowhere have I ever heard of a situation like this. The deadbolt goes well into the hole I drilled for the strike. It is aligned OK.
#10 ·
All these possibilities have been running though my mind. I reluctantly angled the drill to try to avoid a nail head, but it was the same result, and in the process, I widened the @#%ned hole and weakened the board even further. Once I drilled the 1" for the deadbolt, I found a gap behind the board. The right half of the view through the hole is the edge-on view of lath and plaster facing into the living room. The left half of the view, where I want to sink a couple long screws, appears to be old wood. Anyway, I can't make out anything else. But the drill goes into it to a depth of about a 1/4" and comes to a dead stop. What's behind there is anybody's guess. It's clear, though, that I am NOT getting those long screws in place this time.
#15 ·
IF your bolt throws to completion, why keep drilling a 1" hole. You should only be concerned with your screws and drilling pilots for them. Use a 1/8" Tapcon bit or metal bit, but be careful that it isn't a no-nail plate. You don't want to drill through that.
#16 ·
I did my best to describe this. I drilled a 1" hole initially for the deadbolt. Then, to mount the strike plate, I tried to drill two pilot holes for the long anchor screws. I didn't "keep drilling a 1" hole." The two pilot screw holes met some impenetrable barrier that I could not see. That's it. I gave up on it. Strike plate is mounted with 3/4" screws into the jamb wood. I'm done.
