Are all smoke detectors on the same circuit?
17K views 13 replies 10 participants last post by  dmxtothemax
Assuming they were installed correctly, are the 6 identical smoke detectors in my house on the same circuit?
Right now we have a power outage and the darned things are chirping. I know where the one in the basement gets its power and it would be easy enough to change it to a circuit that gets generator power, but unless they all get there power that way it wouldn't be worth the effort.
Its been one hour and the utility claims it will be another 2 hours. We always (about 3x a year...) get it back before they say; lets hope.
Normally yes, but it doesn't necessarily have to be that way. If they're the newer interconnect then it's easier to simply loop one line throughout the house (people almost always take the easy way out).
If they're the older style which don't interconnect then all bets are off. Usually one will snag the nearest available circuit. Probably running off the outlet nearest to it.
They shouldn't be chirping because the power is off unless the batteries are low.
Pull the batteries for now....measure the voltage and replace any that are bad.
#7 · (Edited)
JB... Thanks Bubbi..... I have not encountered that.... but I am laughung my but off....
Do I (or anyone) need a smoke alarm to tell us the electric is off.
It must sound like a bird sanctuary when you have a power interruption.
Who the he11.... NEC, or manufactures, or battery makers, bird lovers, or Facinations Adult Novelty, do you think ran that one thru.
Best
Peter
#8 ·
Robpo said:
My smoke detectors have to be on a dedicated circuit. If that is code in your area I would doubt they would be on two circuits.
Are you sure? Usually the only requirement is that you can't switch it off except with the breaker.
On mine, I tied them to a light ckt. That way I'm 'inclined' to keep them energized if I want those lights on.
To the OP....it sounds like your smokes mite be getting to the end of their life. CO detectors have a 7 year life. After that they won't stop beeping. I have Kidd smokes and comb smoke/CO. When the first one starts chirping, I'll just replace all of them at the same time.
