Has this happened to anyone?
The 3 point lock on an Andersen double hinged french door bought 2 years ago has a problem. When the door is opened from the outside, the lower catch pushes out. This happens after the door handle is released causing the lower catch to push out and protrude from the door. Then, when the door itself is pushed to close, the lower catch being extended about an inch or so, hits the surface of the opposite door and the door is prevented from closing and bounces back open (often unnoticed while the person walks away). The door handle is the very heavy bronzed type and it seems the momentum from the weight of the handle springing back up when released, causes the bottom catch to push out, as though the handle were pulled up which is the normal way the top and bottom catches are extended. How is this adjusted to prevent the spring of the handle's release from pushing the bottom catch out?
Thanks for any help on this. One time the door was left open all night in cold weather because of this.
Tim
Tim
