I have a basement and water is coming in thru the walls.
Id like to do proper analysis of this issue. All contractors do is come by and tell me I need a interior drain and sump pump, and that it will cost me $10K. This might be true, but Id like further analysis done, which I intend to do.
Id just like to do a bit of due diligence before doing what I need to do.
MY QUESTIONS ARE:
1 If I bust out 1 cinder block brick near the area where the water is seeping in, that would be fine, right? I mean, what are the odds 1 brike is holding up a whole house. LOL.
2 If I bust up the floor near that area...not a big hole but something like a 12x12in square so I could actually see under the slab, that would be fine, right? After all, the slab isnt holding the house up and has nothing to do with the structure.
3 Whats the best way to bust up a square in concrete for cheap? Ive already tried drilling 1 hole thru the slab, and that was hell. So, I plan to maybe buy a cheap hammer drill and some good bits to drill holes around the area I want to bust thru.
When it rains, I just want to actually see how this water is getting into the structure. I find it odd that this only happens in like 2 main areas of the basement. If its coming up from the ground, then why doesnt it do this in all areas across this wall.
Thanks
MY QUESTIONS ARE:
Thanks
