Adding outlet in crawl space
7K views 23 replies 7 participants last post by  C'est Moi
Hey everyone. Due to recent flooding in my crawl space, I have added a sump pump. It calls for its own dedicated 15A line. My crawl space is about 5.5ft tall so there is plenty of room to work.
I have two plans that I have thought of:
1. Run conduit from main panel, drill through exterior wall into the crawl space and run 14/1 THHN wire from main panel to a junction box. Then splice the THHN wire to romex inside of the junction box and run the romex to a gfci receptacle near the sump pump.
2. Run conduit from main panel, drill through exterior wall and continue running conduit to a spot near the sump pump where I will connect the THHN wire to a new gfci receptacle inside the appropriate box.
Pricing things out, it's about $50 cheaper to do the romex option. Other than price, is there any reason to do it one way over the other? Am I missing anything? Any other thoughts? Thanks in advance.
#7 ·
I planned on getting white, green and black. I posted only one link to show which wire I planned on getting. Thanks for pointing it out though, you never know. 3/4in PVC was the plan, that way if i can use the same conduit and j box if i decide to add an outlet to my garage for a fridge.
I've read you cannot run romex in conduit, especially going outside.
#13 ·
Any thoughts are appreciated. The white arrows are the things I added.
Overall looks good to me. The conductors on the Romex in the last picture looks shorter than code requires (I'd have to look up what the rule is), I think the slack you're supposed to have is measured starting from where outer jacket is stripped off.
First strap for Romex is not in the picture, that needs to be within 12". (You probably have one, jfyi)
