Access panel behind shower required?
26K views 8 replies 7 participants last post by  Scuba_Dave
I am in the process of re-doing my bathrooms in the house, and with my current re-design for the upstairs bathroom, the shower will be on an outside wall. Meaning, supply lines, mixing valve and showerhead will be all located on an outside wall on the second floor. Am I required to put an access panel behind the shower mixing valve or not?
If it matters, I am located in Houston, TX.
Don't know if an access panel is required in your area. My suggestion is that if it's not required, take pictures of your piping before you enclose them. Supplement the pictures with accurate measurements, especially the distance of pipes from the exterior wall. Then, if you ever need to access the plumbing, you can cut a hole for an access panel without fear.
HRG
Check with local codes but around here it's not required. It likely doesn't get very cold there so you shouldn't have to worry with the pipes freezing. Make sure that insulation is between piping and exterior wall.
#4 ·
Very good suggestions, thanks! I will definitely take pictures and accurate measurements should I need to do anything later. I am using pex for all the piping and will put it on the inside of the insulation.
I checked Houston City codes and saw no mention of a requirement for an access panel.
#8 ·
Be very careful about anything that can come in contact with your pex tubing. Especially, certain types of foam can deteriorate pex tubing. If in doubt, there is pex approved insulation that goes around the tubing which can isolate it from non-approved stuff.
HRG
#5 · (Edited)
Do not put insulation between any pipe and the inside wall, even if the total R value at that spot is less than recommended. Batt insulation may be squeezed between the pipe and the outside wall, or rigid or foam insulation may have a V shaped trench cut out of it as wide at the inside wall as the distance the pipe is from the inside wall.
