ac not cold
1K views 7 replies 3 participants last post by  JJboy
Ok so if it’s not one thing it’s another. outside 96 degrees inside 86
My air is flowing and it is not cold
I go outside and the condenser is running and it will turn off not running very long. But the house air is not very cold and is not cooling the house down. The pipes that go to and from the ac unit are not cold or hot just what i would expect it to be from the normal air around it.
Ideas?
Not used much at all only 7 years old.
It's time to hook up the gauges and check the proper refrigerant charge, check the filter, check if the condenser coil is clean....etc
#8 ·
This procedure is not simple as replace a capacitor .....
