Check your 3rd brake light to see if it works. It has a direct connection to the brake light switch. The left and right stop lights have the multi-function switch, (Turn signal switch) in between the brake light switch and the brake lights. If the 3rd brake light works but the right and left doesn't, then it's usually the multi-function switch or aka, turn signal switch. If it doesn't, and make sure the bulb is good, then your going to have to probe for power until you find it.:vs_cool:
