Hi,
I have 2 recipticals in two adjacent rooms I want to wire. Each will have a 1500 watt heater installed. Its easier to run a 14/3 cable to the first receptical, where I hope to use one hot cable to power the first receptical (black). Then in the receptical box I'd have a 14/2 wire in there that connects to the red cable from the original 14/3 run. The 14/2 cable connects to the 2nd receptical. Another heater will be running off of this circuit (1500 watts). Idea is to be able to run two heaters. The neutral will be shared obviously.
I'm trying to avoid running 2 x 14/2 runs from the panel.
Does this meet code?
Any issue with sharing the neutral with 2 heaters in this setup (1500 watts each)?
