1-part epoxy floor paints - how's the hide on these?
1 reading
12K views 23 replies 9 participants last post by  joeyboy
I have been unable to find much, if any really, relevant info on garage floor paints.
I think I'm just going to use this standard 1 part epoxy behr (I know, I know) stuff.
I was wondering what kind of hide/thickness this may have as I'm beginning floor prep and want an idea of how perfect I need to be when raising voids and scrape/sanding high spots.
Once again, I can honestly say that I have not seen or even heard of that Behr garage floor "epoxy" lasting loner than a few months
And I should add that most didn't make it a few weeks
I'm not trying to pick on them, I've simply never seen or heard of a satisfied customer
There must be some out there....
Even a horrible 20% failure rate, means 80% went OK (though it also means you probably shouldn't risk using it)
But nope...sorry...nothing but horror stories
the failure rate must be HUGE
I think you will be much more satisfied with a concrete stain or a true epoxy
#4 ·
I know I know!!! I hate it! But my general idea is to just get quite a bit more than I need and do touchups.
The problem is that I don't have a lot of good options here unless I want to just go with tiles, which I don't.
The real, 2-part epoxy systems still have ridiculous failure rates - and I read that on contractor talk. If I'm reading that there, I've got no interest in playing with it!! Plus if there's an issue, I can't really do a 'touchup' with a 2part epoxy system.
About staining, that is BY FAR my preferred approach, but I have a slab that has been previously painted, and it's on there good! The process of getting that stuff and the ensuing preparation / work for an acid stain just seems way over the top given the current strong paint on there (and I even have the tinted acid stain on hand, I just don't think it's the way to go because of the prep - this stuff really isn't coming off w/o something heavy duty. I've hit it with a pressure washer (@3500psi with a thin degree tip, up close) and you've gotta work inch by inch, if that. Sanding by hand is completely useless, and I don't think there's any chemical approaches that'd be viable for me (w/o a wet/dry vac or anything, I have too much finished projects around the slabs, including this garage one, which puts me in a bad spot for any large scale chemical attach on this stuff.
So yeah, I really, really don't want to use this stuff. But I've been looking into how to do that floor for MONTHS (literally lol, I started at least 2 threads here on the subject), and it just seems like it's the best fit for the job.
If there's any better, general purpose floor paints or anything I'm all ears. I am painting concrete slabs but as I said, they've already got a very old green paint/coating on them. This stuff just seems to be the best in terms of price, preparation needed, and ability to touchup failure spots. The 2 part system won't allow touchups (which is a major problem given how much they seem to fail), and because of the current condition on the slabs an acid stain job would just be a million times the work and a major, major problem job for me.
At least with this stuff, I can get an extra gallon or two, mix them all up for uniformity into a 5 gal, and have it on hand and do every other month touchups when needed lol!
Any other suggestions are more than welcome, tile is the only one that seems better at this point, but the price differential is just far too much to make it worthwhile for me.
*rehabber - you said the stuff doesn't hide anything? I find that a bit surprising, I guess I was expecting *at least* more hide than a standard paint, you're saying that this epoxy stuff hides LESS than a regular wall paint?
#7 ·
I have no idea what brand it was, but I went to Home Depot, and bought a can of "floor" paint to use on the front door sill, and so far, its holding up great. As far a covering, the sill had been painted white before, and I used black paint. Covered it in one coat.
cool, good to know.
I'll be using this type of paint for:
garage floor
outdoor concrete slabs
several concrete door thresholds
If nobody else has more relevant info/tips and this thread ends here, anyone in the future reading this feel free to bump it and ask me how my work is holding up down the road :wink:
<<I'm doing spots in high sun exposure, rain/elements exposure, high traffic exposure, indoors w/ light traffic exposure, the whole gamut of slab painting, so feel free to ask how it's holding up down the road>>
Hopefully some more comments/suggestions/opinions will come in though :)
#8 ·
Behr offers a line of custom tint concrete stains. I've used them on numerous occasions and they are excellent! It's all in the prep - thorough sweeping, water cleaning, chemical degreasing, chemical etching, thorough rinsing, priming and finally finish coating. It wears well, looks great and unlike epoxy, it's already bonded way down into the concrete. HD carries everything you'll need.
#12 ·
If I were dealing with raw concrete, I'd be all over that, but I have a very strong paint or epoxy already covering the slab. I wish I could go this way because I have some cool (well, I presume so, I haven't cracked the can yet) sherwin williams tan stain on hand already. The amount of prep work to remove that paint would double my prep, which is already the bulk of the job.
Three quarters of your time/effort is in preparing the surface to be painted.
Be sure that the cement has been etched, rinsed and thoroughly dried in any of the questionable areas particularly oil deposits, soap/detergent zones, paint or other chemical spills. The better it is prepped the better the adhesion = longevity.
I'm not applying to concrete though, so there's nothing to really etch - I'm applying to paint and am going to need to sand/scarify a bit for adhesion (and possibly prime).
And yet...there's not one...not one of those coatings professionals that will touch anything with the Behr name on it...
But the guys over there that tried 2-part epoxies and failed (most fail because of improper prep), you'll take that as advice not use a two-part?
Well...if you want to choose the advice that supports your decision as gospel, and ignore the advice that doesn't support your decison, that's your prerogative
Personally, I hope it works out well for you
It seems there are (at least) some success stories with the Behr floor coatings out there
I knew there had to be some!
Good Luck
slick it's not like that, either you're misinterpreting me or I didn't state my case properly.
I am very aware of the ridiculously high failure rate on a 2-part epoxy kit, even amongst people who have done a few of them before.
I also know the 1-part epoxy will be of poorer quality than the 2 part.
What I meant about reading how high the failure rate was on 2-part systems is why I'm not going for that over the 1-part. If there wasn't a generic floor paint or a 1-part epoxy garage floor paint/coating, the 2-part epoxy would be my first choice over the others.
I wasn't asserting the 1-part is better. Rather that the pros outweigh the cons, to me, for the 1-part. I didn't mean that to be that 1 parts are better, I know they are not. But they offer things the 2-part does not. Easier prep (since I'm not etching), cheaper price, and by far the most important to me - ease of touch ups.
If I'm looking at a 1part and a 2part, and know that both have high failure rates, the 1part offers me something the 2part can't - the ability to just grab the bucket, do a quick prep, and touchup an area that had an issue. I can't do that the same with the 2part stuff.
I hope I wasn't trying to imply 1 part was better or anything, I'm aware it's not, but for my purposes and, once taking failure potential into account, it seems a safer bet imo.
#9 ·
Three to One prep time
#13 ·
If you have a good institutional grade (not Kilz) oil base primer handy, try painting over a small and inconspicuous clean part of the epoxy-coated slab. Let it dry thoroughly. In a week or two, see if you can scrape it off easily or if it's on there for good. Try scuffing your feet on it as well. If it's bonded well, then perhaps you can get away with an oil base floor paint. Might be worth a try.
#14 ·
The problem is that each contrete scenario takes a different product. Garage floors are subject to "hot tire pick up". This means all the weight of a vehicle, with hot tires or tires that get turned will come off on the paint or pick the paint up. Simply scuffing with your feet won't tell you anything.
Garage floors are done with behr because "someone" doesn't want to fork over the money for really good, two part epoxy. This is where all the resistance comes from. So simple to go to your local pro paint store and get really good two part epoxy. Follow the directions, and you're good to go. I don't like the high cost of even behr 2pt. epoxy, but this is the clue of what you're getting into. It's not a splash and dash project.
Yeah, prep is the most important thing, but just think about all that prep work and then putting crap on it, because someone didn't want to go another 50 or 100 for good, durable, long lasting 2pt. epoxy. Painting a garage floor is a serious deal if you want it done right. There aren't any corners to cut. It either is, or it ain't.
As far as other decorative concrete, you may get by with behr products.
#15 ·
Joewho - you're making it sound like if I just buck up and drop some extra cash, get the 2 part, and 'do it right', I'll be set.
I want the 2 part stuff, I like it a MILLION times better, I've already said that. The problem is that, even with good brand 2 part epoxies, they still have obscene failure rates!!!! That's the point I'm trying so hard to impress here and I don't think it's coming across right.
I want the look of the 2 part stuff, I want the flakes in the finish lol.
The problem is not one of cash, it's one of convenience. For me to do a 2 part and hope, pray, that my job happens to be the rare one that surpasses a 1 or 2 year window before it starts coming up, just seems foolish.
Whereas with this 1 part stuff, I already know and expect it will have failure spots, but the beauty is that I just get a few extra gallons, and do touchups as necessary - it's not the same as a 2 part in that respect and that's why I'm doing this.
2 parts and 1 parts have ridiculous failure rates. I've heard that many companies DO NOT even do the 2 part epoxy stuff anymore for customers because of the high failure rate. So, even if I do my best, I'm not going to fool myself to thinking I'm close to the level of experience as a professional. I have to accept there's a good chance of failure on any of these systems except tile, and the cost for tile is pointless for my garage.
So, knowing there's a high rate of failure, it seems I'll have a better looking garage by just doign occasional touchups with my 1 part approach, like I'm professing here, as opposed to a 2part approach, where in a year I have big failure spots all over and cannot do anything about it, deal with it, and finally just do the whole floor again. That just seems pointless and way more of a headache than quickly doing a clean/paint every few months on the high traffic areas with this 1 part stuff.
I feel like people are highly disagreeing with my approach and, in all honesty, I just don't understand your reasons why. This isn't a dollars thing (well, the tiles are more than I want to spend, but as far as paint/coatings it's not about the dollars). I can get the kit for a 2 part for my 1 car garage for very cheap (relatively speaking of course). I'm not trying to go cheap and save some cash here, I'm thinking long term. I know both systems will have high failure rates. However, a failure on a 1part, where I still have a gallon on hand, means a quick touchup. A failure on a 2 part means, basically, deal with the failure until you're fed up and decide to redo the entire thing.
Am I missing something? In my head this seems like, by far, the most logical approach for me. I'm not doing this to save cash or anything, it's just that this seems a smarter approach in the long run. If someone who is disagreeing with me in this thread could provide a more thorough explanation of why you feel my approach isn't the best I'd love to hear it, because I'm new at this stuff and want my jobs to come out as good as I can get them too, but no matter how I think of this the 1part with touchups as needed seems to be the best solution available for me.
#17 · (Edited)
All you're missing is faith in this board.
How many times you been here? How many projects have you done after consulting this board? Failurs? Because of our advice?:no:
From you participation here, I really feel you have the skills and ambition to do it. We will help you with the rest. But please, don't assume that if you follow our guidance, it will fail. It's not our track record and it makes me feel like i'm wasting my time.
At least check out what is involved and do it.
Hope you don't take this the wrong way. I just see it in you to do it. I know you can make it succeed.
OK, after all that, if you still want to use 1pt. epoxy, then at least get a protective clear top coat designated for this application
Hope this helps.
#20 ·
I have yet to dabble into this. The pro floor guys use an impressive machine to remove the entire surface of the garage floor to a tectured surface. They then apply two coats of something heavy and a clear. My customers have a finish that only a company that does only these kind of applications will really last. You get what you pay for.
#22 ·
Joeyboy, your obviously a detail fanatic and I mean that in a good way. I do the same thing on all my projects both professionally and the ones on my own home. We're ultra critical of ourselves and our work, you wouldn't believe the minute imperfections I can see in everything. I was actually costing my company money several years ago because I was spending so much time on the details and clean-up, I drove my employees nuts. One of my sales people and my wife(the bookeeper) told me to knock it off and just make it perfect to the customer! Your passionate about what your doing and you want it to be right. Nothing wrong with that. You need to choose the right application for you and your job and that doesn't make it wrong or of any less quality. It's a Myth that all things that are expensive are of good quality. I know tons of guys that charge out the wazoo and there works marginal.
#23 ·
Timber- sooo true, and it's sooo hard to stop isn't it!? I try to tell myself not to go overboard on prep, then the next thing I know, like yesterday, I'm *crawling*, at like 1inch/hr., across the garage floor looking for any little imperfections, I mean like the tiniest bumps, to overlay before the epoxy. I was marking them off with post its, anyways I get up from the floor, and about half of it was yellow!!!!! lol at least it'll be nice and smooth haha.
About the epoxy, I'm VERY impressed so far, especially given that it's a behr product (I HATE their regular paints), and a 1 part epoxy. I know time is the real test, naturally, but this stuff went on strong and is hard to get off even a day after you put it down, two days out I can't scratch it with my finger at all, so that's cool.
And the 1 part turned out to be completely clutch for me. As I mentioned, I was smoothing slabs before hitting them with the epoxy. I did some patching that I didn't smooth out enough, so the patches were showing through like crazy after the paint went on. But, because it's a 1 part, I just went out with a brush and put a thick 3rd coat over the bumpier spots, and it made it noticably more uniform.
Also, the ability to just grab a gallon, instead of a more elaborate 2 part mix, is cool because I went and grabbed a darker shade of gray. My slabs/walkways/patio are all a light gray, but accents, thresholds, etc, are a darker gray, it looks really great actually. The only thing I think I'm gonna hate, barring early failure, is that I won't have the cool color chips on the garage slab...
(oh and I may've mentioned the non-skid additives somewhere in this thread as well, I think it's a crystalline silica powder basically. I used that at ~1oz/gallon for a sloped walkway, and you cannot tell there's any texture to it, but the grip is there. I know these will make the epoxy fail quicker, but luckily, even that spot passed the 2nd day fingernail scratch test ;) )
#24 ·
(oh and another thing, it says 300-400 sq ft / gal, I was getting less than, but almost, 300/gal on my first coats, and probably like 400-500 on the 2nds... didn't measure for the second so that's just a guess, but the 1st coats were getting about 250-275sq ft depending how much old paint was intact on the slab)
