I have this yard machine electric start mower. Not sure how the electric start works but the primer bulb leaks theres tiny needle hole in the front of it would this cause air into the fuel system vs vacuum feeding fuel to engine and kill the motor after 1-2 seconds. It starts normally by pullstarting and primer bulb but the primer bulbs leaks small amount of gas has a tiny hole on the top of it. No primer bulbs are suppose to leak are they. is full of clean oil.
Any idea what these run or cost new not sure how the electric start works if theres a battery pack somewhere im not aware of a charger port? Has a key but starts by normal pullstarting key off position and dies after 1-2 seconds as i think the primer bulb has a tiny leak as a small amount of gas accumulates on finger tips when pumping and just under primer bulb area of mower. Know the fix?
