What is the proper way to wire 3way dimmer to 4 can lights to a 3 way switch?
10K views 17 replies 3 participants last post by  daxlw
What is the proper way to wire a 3 way dimmer switch to 4 recessed lights and then to a 3way switch? What is the correct wiring instruction?
#4 ·
If the circuit is 15 amps you can use #14.
The easiest way is power to S1 with xx-2, between S1 and S2 with xx-3, and then xx-2 to the first light. Incoming and outgoing hots on the black screws, black and red from xx-3 cables as travelers. All whites to whites.
