I have a Troy Bilt 4-cycle gas powered weed wacker (TB 675 EC). The thing is great, no mixing gas and oil, it's a beast compared to smaller electric models, and I've also had very good luck with the pole saw attachment.
The problem is that the thing is heavy, and really gets hard to hold by the time you get halfway through your yard. So I went and bought a troy built 'universal fit' weed wacker shoulder strap. I figure it would solve all my problems, but it does not. Here is a picture of thing hanging on my wall with the strap attached:
So as you can see, both ends of the strap are ahead of the handle! And of course, all the weight is in the engine. So when you put this thing on your shoulder, the engine falls straight down, so you have to hold it the whole time with the handle. And that handle is now uncomfortably far behind you. You can loosen the strap and push the thing out in front of you, but then you end up holing most of the weight of the thing with your arms defeating the purpose of a shoulder strap.
What you need is someplace on the motor to hook one end of the strap, so everything would be balanced. But there is no such thing, it's all cheap plastic moulding that looks like it would break very easily if you tried to support it's weight with it.
Note that the reason it's balanced on the wall is because one hook is directly under the motor, and the other is just ahead of the front most handle (not the one with the trigger).
Anyone have any thoughts on this? It's a great weed wacker otherwise, but I have a large yard and it's brutal using this thing without a proper shoulder strap.
