Hello,
I have a Mark 89 Culligan Watersoftener system and it does not appear to be working anymore.
From what I can tell, there is no flow out the drain line during any part of the regeneration sequence.
I manually moved the timer through the sequences and where I expect a backwash, there is none.
The brine tank is full of water and there are cycles were I can see a low flow of water into the tank and then a higher pressure flow of water.
I found this by pulling the brine line and moving the float around to engage or disengage.
Does anyone know which stage of the process the low flow is? Which stage has the higher pressure. I have lost track of the switch position for the various stages now as well.
Does the drain elbow pull out or screw out of the assembly?
Will cleaning inside help this? Is there a filter or screen that could be plugged?
Or, could it be a more significant problem such as a motor or pump?
I have the manual, but it doesnt really tell me how to do maintenance or take things apart.
Thanks
Thanks
