Attached photo is the gauge. I don't know where I got the gauges from. Amazon, homedepot. Brand is simmons. I probably bought them after some research or based on the reviews. I used one of it for my parents whole house pressure reducer.
Recently I posted leaky gauge from amazon and why I think it leaks. So made one with parts I had plus the hose connector which is solid piece of 3/4 garden hose x 1/2" threaded male. Hose nut doesn't spin, which is now I understand the need for the red needle. Since nut doesn't spin, gauge may be facing away from me. This setup doesn't have the relief either.
Anyway, on basement utility sink faucet, I got 80 psi. Very surprised. I thought this house actually had lower pressure. I never had any water banging. Never had any leaks from boiler or the water heater.
The gauge is 1/4" thread with a hole little larger than 1/16"? That shouldn't matter with water pressure? As I understood it, water pressure is same everywhere, any size. Please confirm or correct me. The number is from cold side and as far as I know, hot water doesn't mix anywhere. Boiler also has a reducer which is also a one way valve, I think.
Finally, wondering if anybody can recommend a gauge that can be trusted? Pro store? What can I use as a standard? I included back of the gauge to show it's nothing special.
But based on the reading, I am going to add whole house reducer.
