Water in basement in older home
1 reading
3.4K views 10 replies 6 participants last post by  RWolff
Your problem is, that the house has that slope on the deck side, that is directing the water towards that side of the foundation. All you can really do, is build a berm to direct the water away from the garage & house. Also you may end up having to dig around the foundation on all four sides of the house, to install a perimeter drain system to direct any ground water around the footings, into a sump well, if there is not already one.
Another item that I can see, is that your gutters and downspouts are a little undersized, along with the fact that the water is directed into that plastic drain tile, are you sure that there is no clog in the line, which can also cause backup against the foundation.
This Summer looks like it will just continue to rain forever. If you are willing to foot the cost of having a plumber camera snake the drain tile, I would maybe have them do that, then you can see what the previous owner did, and where they run to.
