I need to change the Temperature/Pressure Relief Valve, it keeps making a hissing sound and water is constantly flowing through the dowward PVC pipe that is located to the right of the water heater, this PVC pipe needs outside). Problem is I need to remove the copper connector and the PVC pipe that is connected to the valve.
It looks like I just have to saw the PVC pipe at some point and then just reconnect it correct? If so, simple enough, get some small saw and carefully hack away. Then how do I reattach?
