I am trying to install a vintage green Kohler toilet and am having a problem with incomplete flushing. I’m pretty sure the problem is mineral deposits. I can flush the toilet with a bucket. When I flush the tank, the water in the bowl swirls but the level stays the same. I’ve removed some thick deposits from the areas in the bowl that I can reach and, even after leaving a half gallon of vinegar in the bowl for two nights, I can feel that there’s still more. I’ve poked the rim jets with a coat hanger and didn’t notice any blockage there. The siphon hole on this toilet is deep inside at the back of the bowl, barely reachable and impossible to see. I can’t tell if or how much it might be blocked. I might be able to maneuver a flexible tube into it, but a coat hanger would be impossible.
I’m wondering if I’m on the right track with the vinegar. The mineral deposits are almost 1/8 of an inch thick in spots. I don’t mind letting the vinegar sit for as long as it takes, but how long is reasonable? Once the weather warms up, I was thinking of taking the bowl outside, adding the vinegar, sealing the openings with plastic wrap and letting the whole thing kind of steam. I have nothing to lose at this point and I’m not ready to give up on this fun, colorful toilet.
FYI, this toilet originally had an Aqua Vent system which was disabled long before I got it and, I believe, was functional without it. It was also sitting in a garage without a tank lid for quite awhile.
