Alrighty. We have a 24x24 metal building that has about 4” of spray In insulation on the walls/ceiling. it has a 12x12 roll up door and a walk in door. The air inside gets very stale and warm. even when we open the doors it still tells gross sometimes. We don’t have moisture issues but just a lack of fresh air. I’ve noticed when I climb a ladder, when I get to about 10’ the air temp changes. It’s like there’s a pocket of hot air that won’t move!!! would and exhaust fan in the rear help? With maybe an intake vent on front side? it has an 8’ fan that moves a little bit of air but I’d like to keep fresh air “circulating” if possible.
Also we have a 24x12 add on, uninsulated, it gets hot bein in the metal box, would adding a a vent in the rear and opening the roll up door help move air through? Or maybe some vents on the peak of the walls to let hot air out like an attic? There will eventually be a door installed to separate the two. Also there is a window on the side wall. I’ve attached some pics. Thanks
