I'm at the rough-in stage of my master bathroom remodel. So far I've done everything myself and I'm hoping to do the plumbing myself. I'm under UPC code in WA state and I'm hoping someone could take a look at my layout.
Everything is permitted so I will need to pass plumbing inspection. I'm pretty sure my layout is correct but I'd rather not fail inspection and have to start over. I'm going to talk to the inspectors about needing test tees to do a standing test of the new vents so I'll probably have to add a test tee to the 1.5" line going to the tub. There is already one in the 3" line before it goes into the "stack".
The DWV is all ABS (it's just orange in the drawing to see it better)
The top right is a 2" p-trap for the shower with 2" drain and 1.5" vent. There are 22.5 degree offsets to lower the wye so it can be "rolled up" to 45 degrees. This drops it about 1.5" so the top of the wye is still above the weir of the p-trap. The vent has a long turn 90 where it goes up into the wall because it is below the flood level.
The shower has a similar setup except with a 1.5" trap and drain.
The vanity p-trap at the lower left goes into the wall and over to the existing 2" stack vent and connects with a sanitary tee.
The toilet in the lower right goes straight down under the joists in a soffit to a long turn 90 and has two long turn 45s before it goes into the existing double-fixture fitting in the stack.
Also here's pictures of the actual floor to give a better visual. Joists are 2x8 so the 2" p-trap barely fits inside the floor vertically.
