1 - 2 of 35 Posts
If it has the plate straight in is the best connection. A
If it don't have plate wrap B
back connection is called back stab and you are correct stay away from that.
Cowboy
Reactions: Idrivea911
I'll be happy to be corrected, but I believe when you stick the wire in the back, you tighten the screw and it clamps onto the wire inside.
No if you cut one open you will see it is a spring clip, that is why you can't pull them out after inserting the wire. On an industrial one you are correct they clamp the wire by screw.
If you look at his screw B picture the hole for the push in is not even near the screw.
Cowboy
Reactions: Mike Milam
1 - 2 of 35 Posts
