My kids bathtub was draining slowly until my kid poured dirty water from his fishtank in the tub. Now it is completely blocked.
Here are the facts:
1. There is no access under the tub. It's a tri-level house.
2. One waste pipe comes down to the basement from that floor and the tub is the only thing that is blocked. The sink, shower and toilet all drain fine. They all empty into the single pipe.
3. When I run a snake into the tub overflow, it seems to hit an obstruction (the P-trap perhaps) and then continues down for at least 6 feet without an obstruction. No hair at the end of the snake when I pull it up.
4. Pulling the snake out does not clear the blockage in any way.
5. When plunging the drain, water comes out of the overflow. When blocking the overflow, I can pull and push the plunger but the blockage persists.
6. My house was built in 1962 so there might be a tub drum trap but I see no evidence of one.
7. Did not try a chemical drain cleaner and will not go that route.
What I do not understand is that if the blockage is further then 6 feet down the pipe (since I snaked at least 6 feet) why then are no other drains blocked? The sink and toilet are much closer then that to the tub.
I wish I had one of those cameras that I could snake into the overflow and see what's causing this problem. I will probably need to bite the bullet and call a plumber on Monday unless I can think of something else to try or if anyone has any ideas. I've been cleaning out blocked drains for years but this one has me stumped.
Thanks for your good advice.
Here are the facts:
