There is not a big enough gap between the bottom of the exterior door and threshold
16K views 15 replies 5 participants last post by  mguise
The threshold is built into the frame and attached from underneath--
They can be replaced but it's not an easy task.
Often the best solution is to cut off the bottom of the door and add an aluminum door bottom with a rubber sweep---
Find the aluminum door bottom before you cut---that might be a search---
I've cut those with a circular saw using a carbide wood blade---wear eye protection--
