Tearing Down Plywood Walls
1 reading
3.4K views 5 replies 4 participants last post by  Ron6519
So much to my displeasure, I found in the course of my bathroom teardown that the lower halves of the walls are not drywall nor backerboard...they're plywood!
My question is what is the best way to go about removing the plywood? I can't just hammer it down. Do I cut along the studs w/ a reciprocating saw and pry it off?
I wouldn't recommend a reciprocating saw for this task. I also don't know that I'd cut along the studs personally, as that's where all the fasteners will be. Unless you have a dislike of your blade, saw motor, and limbs.
Set your circular blade depth to just less than the plywood's thickness (to avoid hitting electrical or plumbing). I'd have the electricity and water off just in case. Cut on either side of the studs they're fastened to, and anywhere else you want the sheet to come apart (for disposal). Wearing a mask would be a great idea.
Should come right down.
