Tandem Breaker in old electrical panel
893 views 4 replies 5 participants last post by  SW Dweller
I am installing a dedicated circuit for a bathroom outlet. Attached is a picture of the old Sylvania panel. My understanding from looking at this is that this panel does accept tandem breakers seeing as it is a “20/40” panel. Can I use the breaker pictured? It says that it is type A which the panel lists as acceptable. Is this actually acceptable? And should I be using a CTL rated breaker or a non-CTL breaker?
#4 ·
I may get this wrong so help me out if I do so the Discussion Starter doesn't end up the proverbial creek. If a panel is labeled 40/60 for the number of breakers only half of it's full slots should except tandem breakers. That would mean that it still has to be a Circuit Limiting (CTL) panel wouldn't it? It follows that it should only except CTL breakers and those only in the 20 tandem breaker accepting slots right?
Tom Horne
#5 ·
CTL, which stands for circuit total limitation, is a term commonly associated with "twin" or 2-in-1 breakers utilized in residential load centers. These CTL breakers possess a rejection feature on the bus connection side, specifically designed to prevent their usage in specific areas within a load center.
The only way to know for sure is to contact Eaton and ask them about your panel.
I do not like "twin" breakers and especially do not like mixed amperage breakers. There can be so many rules where they can be installed. Not just in the panel, but WHERE on the panel bus.
