Putting a new whole house well water filter system in.
Spin down and other filter located in a heated utility room in garage. I would like to discharge the spin down filter into the ABS house drain about 30 ft away. A water trap is my concern ?
Can I use PVC tubing and create a water trap prior to my tap into the drain pipe ? Or use PVC pipe with a J trap prior to the drain line ? I cant visualize the proper PVC fittings to create the trap ?
Any suggestions or guidance ? Thanks
Steve in NC
Steve in NC
