I'll be sistering 2x4 studs (original studs have a bit of termite damage). What size and length nails should I be using to toe nail the new studs to the top and bottom plates (plates are also 2x4, with bottom plate being pressure treated). I'll be using a hammer (no nailer, and probably not worth investing in a nailer for the 6-8 studs I'll have to sister), if that makes a difference.
Since I'll be sistering and will only have access to drive nails from one side, are 2 nails each at the top and bottom sufficient? Should I use the same nails to attach the new stud to the damaged stud (will find sturdy spots on the damaged stud)?
