Sistering Roof Rafters
37K views 11 replies 7 participants last post by  JustinK
1) will sistering a 2/4 to the side and not the full length provide the required stability
2) are 3/8" bolts to wide for a 2x4 or even a good choice?
Ayuh,.... I would probably sister 2, 2x4s, 1 on each side of the failin' wood, as long as possible to get into place,.....
After I jacked things into place(straight), I'd probably run in 3/8" lag bolts, clean through all 3 pieces of wood, to end up with a bolt every 12"/ 18" of the length,...
