Hello all,
I'll start siding my new house in about 2 weeks but just finished a walk about for it. When they framed the house they framed it "square" but not directly flush with the foundation. The RIM joist / sill plate sits back and tappers up to 1 inch from the concrete exterior wall in one area. I'm doing 12 inch, 7/16 LP Smartside siding.
So my questions is this, my starter strip and siding will only be 7/8 thick so it won't cover the entire foundation exposure. My plan was to put some Z flashing over the exposed concrete. Is this acceptable? If so how far should that flashing go down the concrete? 1/2? 1 inch? Also what metal doesn't react with concrete?
This also comes to the fact that I thought that you started half inch lower then the sheathing for water purposes. So to keep the siding look level around the entire house do you think i should be putting flashing around the entire house now because the siding basically sits on the concrete on certain spots and is flush with the bottom sheathing?
I forgot to take pictures so I'll post some later tonight.
Thanks for any help, much appreciated.
