Screw through inside of box not allowed?
17K views 16 replies 11 participants last post by  petey_c
I've got a little backtracking on design situation here where after putting in new construction single double switch box nailed to exposed stud, I'm going back in through sheet rock and changing to double sized box. Because of the opening in sheet rock around current single box is a little too high, at this point when widening and putting in double sized box it would be much easier to just drill a couple screws from the inside of the switch box and right into the stud. Is that a total NO-NO for electrical safety? I would cover the screw heads with a smear of heavy PC-11 epoxy paste which is non-conductive.
I would not put a screw through the box. When I put in just a few receptacles in a small renovation of a bathroom I had to with one plastic single gang box to help secure it with a sheetrock screw. The inspector failed it and stated "by putting a screw into the wall of the box you have compromised the integrity of the box". I had to remove the box and reconfigure things. It really depends on the inspector. The boxes are approved by UL in use as "as they are manufactured" not as you alter them.
#6 ·
Exactly, this topic came up on another forum about using the small holes in the side covers of the box.
Most if not all of the responses had no problem with it.
My question is "why" would those little holes be there in the first place?
I saw them on 1900 boxes too, but I believe there is a clamp that clips on that uses them.
But in general, most metal boxes have them (the small holes).
#10 ·
What is wrong with a screw through the box?
I suppose you could have an electrical fire so hot and prolonged that it heats the screw up enough to burn the stud; but that seems really really unlikely. Some other reason?
#15 ·
"Nails and screws, where used as a fastening means, ... or they shall pass through the interior within 6 mm (1/4") of the back or ends of the enclosure. " 314.23 (B) (1) "This requirement prevents nails from interfering with the installation of devices. Permitting nails inside the box within 1/4" of the ends reduces splitting of the smaller wooden studs used in some frame type construction." Thanks to the '08 NEC Handbook
