Hey all. I'm new here, and thought I would make my first post showing a retaining wall I'm building. As you can see in the pic, I built one small wall at the top to park the car. Now, if you look at the siding, there are 2 levels where I plan to put my blocks up to the foundation and create 2 tiers to fill and level off for some gardens. There is already a corregated drain pipe buried along the slope against the house. I plan to seal the concrete, and add a layer of plastic vapor overlapping the existing barrier by about 6 inches. The walls will be about 3ft high, and built just like the one at the top, creating a 5ft wide sloped walkway on the left for clean gravel. That's also where I plan to focus all the run off from rain that currently flows down and towards the house as you can see by the erosion pattern.
Any other tips you guys may have is appreciated.
