Hi All..
I am new here but have been reading the posts hear for a while.
I would like some help on my up coming project where I need to replace
a shutoff Gate Valve on a 1 inch copper supply line. As you can see in the pictures below, I currently have a gate valve that will not shut off completely. I have a city ball valve in the water meter ground vault that I close when I need to do work in side the premises , but I need to fix the main shut off. My question is to get the opinion of the pros on line here about soldering the joints on the 1 inch pipe that is coming out of the ground (with concrete around it). I am fearing that will not get enough heat into the joint to sweat it correctly. What I was planning to do is to cut the existing pipe above and below the gate valve and then replace it with a ball valve with pieces of pipe already solder on to the ball valve. I would use copper couplers on the top and the bottom to joint the existing pipe with the new pipe. I was planing to use MAPP gas, but am wondering if I should use acetylene due to the 1 inch pipe and the ground cooling. I was planning to suck the water out of the inlet (coming from the ground) with a piece of vinyl tubing as far down as I could stick in down the pipe.
Can anyone who has tackle a task like this comment on the soldering challenges?
Thank You
Joe
Thank You
Joe
