I have a 2-car detached garage that was built back into a bank at the base of a mountain, typical West Virginia style, and over the last 60 years or so the walls have been pushed in. I just bought the property 6 months ago, sight unseen, and the real estate agent was less than honest about the garage walls.
I am going to fix it myself. The local contractor would charge 20 - 30 grand to do it. I just went to Lowes this morning and bought $74 in tools and material to DIY. I started digging it out by hand but soon realized the rocky soil and the amount of soil I had to remove would be very slow going so I bought a tow behind backhoe on Market Place and things are moving right along now. Photo of my hand digging progress.
I dug out behind the back wall already and then used the back hoe on the inside to push the wall back where it belongs, almost. A previous owner pointed the blocks after the mortar seams opened up so I have one more (maybe 2 more) mortar seams to chisel out then it should be perfectly straight again with a little push. There is about a dozen blocks I will have to replace as well. The bottom row of blocks was pushed in about 2" and that was easily pushed out with the backhoe.
There are large sections of blocks with no cracked mortar so it shouldn't be too hard to tuck point the broken mortar seams once I get them cleaned out. I picked up a 3/8" tuck pointer and a jointer this morning along with some bags of ready mix and a sack of type S mortar mix. A previous owner used jack poles to keep the side walls from totally collapsing. Photo of dug out back wall.
People tell me I need to use gravel as fill but I'm not going to put much fill back, maybe only 2 or 3 blocks deep. In places where I have to replace a block I'm filling the blocks with concrete. I just came from living in the Philippines and they have very bad hollow blocks, but they fill the hollows with mortar and have rebar attached to the foundation in every 5th hole going all the way up to the roof trusses.
The garage was built in 1960 according to tax records. No plywood was used in the construction, only 1x10 planks. The attic is a room that will be my wood shop. There is a door on the back that is close to ground level. I also want to put a flue pipe through the wall somewhere for a wood stove. Any tips on what I'm doing is appreciated. I can do, and have done, every phase of house construction, except laying blocks. I'm thinking about the blocks I'm replacing in the middle of the wall. Maybe lining them up with spacers and tuck pointing around them?
Thanks
